  3. Smart Life
  5. What to do if the remote control cannot control the volume through the TV box?
2026-06-02 129 1
Welcome to Blackview (World's well-known brand of rugged smartphone and tablet) blog. Hope the guide helps.
It can be frustrating when your remote control works for channel navigation and menu operations but fails to adjust the TV volume through the TV box. This issue is common with cable boxes, Android TV boxes, IPTV devices, and streaming receivers. In many cases, the problem is related to remote pairing, incorrect control settings, signal interference, or a software configuration issue rather than a hardware failure.
A person is using a remote control to adjust the volume of a TV box
Before replacing the remote control or contacting technical support, it is worth performing several troubleshooting steps. By checking the remote settings, confirming device compatibility, and reconfiguring the volume control function, most users can restore normal operation within a few minutes. The following guide explains the possible causes and provides detailed solutions.
Check Whether the Remote Is Programmed Correctly
Many TV box remotes need to be programmed or paired with the television before they can control volume functions. If the pairing information has been lost after a reset, battery replacement, or software update, the volume buttons may stop working.
Steps to Verify Remote Programming
Follow these steps to confirm that the remote is configured correctly:
  • Open the TV box settings menu.
  • Navigate to Remote Control or Device Control settings.
  • Select TV Control Setup or a similar option.
  • Check whether the television brand is correctly assigned.
  • Re-pair or reprogram the remote if necessary.
  • Test the volume buttons after the setup is completed.
Inspect the Remote Control Batteries
Weak batteries may provide enough power for basic navigation commands while failing to transmit certain control signals effectively. This can cause inconsistent performance, especially when controlling external devices such as televisions.
Battery Troubleshooting Procedure
Use the following process:
  • Remove the old batteries from the remote.
  • Install a new set of high-quality batteries.
  • Ensure the battery polarity is correct.
  • Clean the battery contacts if corrosion is present.
  • Restart the TV box and test the volume function again.
Verify TV and TV Box Control Settings
Modern TV boxes often allow users to choose whether volume buttons control the television, the TV box itself, or an external audio system. Incorrect settings may prevent the remote from adjusting the desired device.
How to Check Control Configuration
Review the settings carefully:
  • Open the Settings menu on the TV box.
  • Select Device Preferences or Remotes & Accessories.
  • Locate Volume Control settings.
  • Choose TV Volume instead of Box Volume if available.
  • Save the changes and test the remote.
Eliminate Signal Interference
Infrared and Bluetooth remotes can be affected by environmental factors. Objects blocking the signal path or interference from other wireless devices may prevent volume commands from reaching the television.
Steps to Reduce Interference
Try the following actions:
  • Remove obstacles between the remote and the TV box.
  • Clean the infrared sensor area.
  • Move nearby electronic devices away temporarily.
  • Re-pair Bluetooth remotes if applicable.
  • Test the remote from different positions.
Update or Reset the TV Box
Software bugs can occasionally affect remote-control functionality. Installing the latest firmware or performing a reset may resolve unexpected control issues.
Update and Reset Instructions
Proceed with the following steps:
  • Check for available software updates.
  • Download and install the latest firmware.
  • Restart the TV box after updating.
  • If the problem remains, perform a factory reset.
  • Reconfigure the remote after the reset process.
If the remote control still cannot adjust the volume after completing all troubleshooting procedures, the issue may involve hardware incompatibility, a defective remote, or a malfunctioning television receiver. Testing with another compatible remote can help determine which device is responsible for the problem.
In most situations, restoring the correct pairing settings, replacing batteries, adjusting volume-control options, or updating the system software resolves the issue. Regular maintenance and software updates can also help prevent future remote-control problems and ensure a smoother entertainment experience.
Prev article: How to reset your TV box?
Next article: How to use the phone keyboard on a smart TV?
