  3. How To
  5. How do I know if my phone supports WiFi 7 and is using WiFi 7?
2026-11-05 38 0
Welcome to Blackview (World's well-known brand of rugged smartphones, including rugged phone with projector, rugged phone with eSIM, and rugged phone with satellite messaging, etc.) blog. Hope the guide helps.
WiFi 7, officially known as IEEE 802.11be, is the latest generation of wireless networking technology designed to deliver faster speeds, lower latency, greater bandwidth, and more reliable connections than previous WiFi standards. As smartphones, routers, and home networking equipment increasingly adopt WiFi 7, many users want to know whether their current phone supports this technology and, more importantly, whether it is actually connected through a WiFi 7 network. However, having a modern smartphone or seeing a fast internet connection does not automatically mean that WiFi 7 is available. Hardware compatibility, software support, router capabilities, and network configuration all play important roles.
A man checks if the phone supports WiFi 7
Fortunately, checking WiFi 7 compatibility and connection status does not require advanced networking knowledge. You can start by examining your phone's technical specifications, checking its operating system and wireless settings, and identifying the capabilities of your router. You can also use network diagnostic applications to gather more detailed information about your current connection. This guide explains how to determine whether your smartphone supports WiFi 7, verify whether it is actively using the standard, troubleshoot common connection problems, and get the most out of this newer wireless technology.
Check Whether Your Phone Hardware Supports WiFi 7
The first step is determining whether your smartphone has WiFi 7-compatible hardware. WiFi 7 support cannot generally be added through a software update if the phone's wireless chipset does not support the standard. Therefore, checking the manufacturer's official specifications is the most reliable starting point.
Find Your Phone's Wireless Specifications
Look up your exact phone model on the manufacturer's official website. Do not rely exclusively on the product family name because different versions, regional editions, and storage configurations can sometimes have different wireless capabilities.
Follow these steps:
  • Open your phone's Settings application.
  • Navigate to About Phone, About Device, or System Information.
  • Find the exact model name and model number.
  • Visit the manufacturer's official product specifications page.
  • Locate the Connectivity, Wireless, or WiFi section.
  • Check whether the specifications explicitly mention WiFi 7, IEEE 802.11be, or 802.11be support.
If the specifications list only WiFi 6, WiFi 6E, or IEEE 802.11ax, your device does not officially support WiFi 7 through its documented wireless hardware capabilities.
Understand the Difference Between WiFi 6E and WiFi 7
WiFi 6E and WiFi 7 are frequently confused because both can operate in the 6 GHz frequency band. However, they are different wireless standards.
  • WiFi 6: Uses the 2.4 GHz and 5 GHz bands.
  • WiFi 6E: Extends WiFi 6 capabilities to the 6 GHz band.
  • WiFi 7: Introduces advanced technologies, including 320 MHz channel bandwidth, 4096-QAM modulation, and Multi-Link Operation (MLO).
Therefore, seeing a 6 GHz connection does not automatically mean your phone is using WiFi 7. You must verify the supported wireless standard rather than relying on frequency alone.
Check Whether Your Phone Is Actually Connected Through WiFi 7
Knowing that your smartphone supports WiFi 7 is only half the process. To establish a WiFi 7 connection, your router or access point must also support the standard, and the network must be configured appropriately. Even a compatible phone can connect using WiFi 6 or an older standard when the network does not provide WiFi 7 connectivity.
Check Your Phone's WiFi Connection Information
Start by opening your phone's WiFi settings and selecting the currently connected network. Depending on the manufacturer and operating system, you may find additional information under Network Details, Connection Information, or Advanced Settings.
Look for the following details:
  • WiFi standard: Check whether the connection is identified as WiFi 7 or 802.11be.
  • Frequency band: Identify whether the connection uses 2.4 GHz, 5 GHz, or 6 GHz.
  • Link speed: Check the negotiated wireless connection rate.
  • Channel bandwidth: Look for wider channels, particularly 320 MHz where supported.
  • Multi-Link Operation: Check whether MLO is available and active.
Not every smartphone displays all these details. Some Android manufacturers provide extensive wireless diagnostics, while others show only basic connection information. iPhones may also provide limited details through their standard WiFi settings.
Use a Network Information Application
For more detailed information, consider using a reputable network diagnostic application. Depending on your operating system and device permissions, these applications may display the connection frequency, channel, signal strength, negotiated link speed, and other wireless parameters.
On Android, applications such as WiFiman or WiFi Analyzer can help investigate network conditions, although the information available varies by device. Some diagnostic applications cannot directly identify the negotiated WiFi standard, so consult their documentation before treating a displayed value as definitive evidence.
On iPhone, Apple's AirPort Utility can provide WiFi scanning information when WiFi Scanner is enabled in the application settings. However, scanning nearby networks does not necessarily confirm the exact standard currently negotiated by your phone.
The strongest evidence is an explicit WiFi 7 or 802.11be connection indicator from the phone's system diagnostics or manufacturer-supported network tools.
Make Sure Your Router and Network Support WiFi 7
Your smartphone cannot establish a WiFi 7 connection independently. The wireless router or access point must also support WiFi 7, and its firmware and configuration must allow compatible devices to connect using the newer standard.
Verify Your Router's WiFi 7 Compatibility
Check the router's model number, product label, user manual, or official manufacturer specifications. Look for WiFi 7, IEEE 802.11be, or explicit 802.11be support.
Next, access your router's administration interface or mobile application and review its wireless configuration. Depending on the router, you may need to:
  • Enable the 6 GHz wireless band if you want to use it.
  • Enable WiFi 7 or 802.11be compatibility.
  • Update the router to its latest stable firmware.
  • Use a supported security configuration, such as WPA3 where required for 6 GHz operation.
  • Check whether the 320 MHz channel option is available and permitted in your region.
  • Confirm that MLO is enabled if your router and phone support it.
Keep in mind that not every WiFi 7 connection requires a 6 GHz band or a 320 MHz channel. WiFi 7 can also operate using supported configurations on other frequency bands.
Understand Multi-Link Operation (MLO)
MLO is one of WiFi 7's most important innovations. Traditional WiFi connections generally communicate over one wireless link at a time. With MLO, compatible devices can use multiple links across supported frequency bands to improve throughput, reduce latency, and enhance connection reliability.
However, MLO requires compatible hardware and software on both the smartphone and router. Simply connecting to a WiFi 7 router does not guarantee that MLO is active. Some devices support WiFi 7 without exposing all MLO capabilities to users.
Troubleshoot Problems When WiFi 7 Is Not Working
If your phone supports WiFi 7 but appears to connect using an older standard, several factors may explain the problem. A systematic troubleshooting process can help identify whether the issue comes from hardware compatibility, router configuration, software, or wireless interference.
Follow These Troubleshooting Steps
  • Restart both devices: Restart your smartphone and router to refresh their wireless connections.
  • Update your phone: Install the latest available operating system and manufacturer-provided firmware updates.
  • Update your router: Check for firmware updates that improve WiFi 7 compatibility and stability.
  • Forget and reconnect: Remove the saved WiFi network from your phone and reconnect using the correct password.
  • Check security settings: Make sure the router uses a security configuration supported by your phone, particularly on 6 GHz.
  • Check regional restrictions: Available WiFi frequencies and channel widths depend on local regulations and device certification.
  • Test near the router: Move closer to reduce signal loss and interference during testing.
Do Not Confuse Internet Speed With WiFi 7 Performance
One common mistake is assuming that a high internet speed proves a WiFi 7 connection. This is not necessarily true. A phone connected through WiFi 6 can achieve excellent internet speeds, while a WiFi 7 device may deliver disappointing results because of a slow broadband connection, network congestion, or weak signal strength.
For a more meaningful test, compare your negotiated WiFi link speed with your actual internet speed. A local network speed test between your smartphone and a wired computer or network storage device can help separate wireless performance from broadband limitations.
How to Get the Best Performance From WiFi 7
Once you have confirmed that your smartphone and router support WiFi 7, optimizing your network configuration can help you experience its benefits. However, maximum theoretical speeds are not guaranteed in everyday environments. Actual performance depends on distance, obstacles, interference, channel availability, router capabilities, and the phone's antenna design.
Optimize Your Wireless Environment
  • Place your router in an open, central location rather than inside a cabinet.
  • Keep your smartphone relatively close to the router when testing high-speed connections.
  • Use the 6 GHz band when supported and appropriate for your environment.
  • Choose wider channels when permitted and when interference conditions allow.
  • Enable MLO if both devices support it and the feature is available in their firmware.
  • Avoid unnecessary wireless congestion from multiple devices and overlapping networks.
  • Use a sufficiently fast Ethernet connection between your router and modem or internet gateway.
Evaluate Real-World Performance
Instead of focusing exclusively on advertised maximum speeds, evaluate WiFi 7 through everyday activities. Test large file transfers, high-resolution video streaming, online gaming latency, and simultaneous connections across multiple devices.
WiFi 7 is particularly valuable in environments with demanding wireless workloads because its wider channels, improved modulation, and MLO capabilities can provide greater capacity and responsiveness. Nevertheless, the benefits depend on whether your smartphone, router, and network environment can take advantage of these features.
It is also worth remembering that a WiFi 7 connection does not automatically improve your mobile data speed or cellular coverage. WiFi and cellular technologies operate independently.
Ultimately, the most reliable way to confirm WiFi 7 usage is to combine three checks: verify that your exact smartphone model supports IEEE 802.11be, confirm that your router supports and enables WiFi 7, and inspect your phone's active connection information for an explicit WiFi 7 or 802.11be indicator. Frequency, signal strength, and speed tests provide useful supporting evidence but cannot independently prove the wireless standard.
As WiFi 7 becomes more widespread, understanding these distinctions will help you make better decisions about smartphone upgrades, router purchases, and home network optimization. By checking compatibility before troubleshooting and measuring actual network performance afterward, you can determine whether your phone is simply WiFi 7-ready or genuinely benefiting from a WiFi 7 connection.
Prev article: How to block and unblock someone on Messenger on a phone without them knowing?
Next article: How to check & retrieve deleted messages on Messenger on your phone?
