  3. How To
  5. Why & How to fix WhatsApp app not working on WiFi but working on mobile data (Android/iOS)
2026-09-14 168 0
Welcome to Blackview (World's well-known brand of rugged outdoor smartphone, such as eSIM rugged phone, thermal camera phone, Android 16 rugged phone, etc) blog. Hope the guide helps.
WhatsApp normally works through both WiFi and mobile data, so when it works perfectly on cellular data but stops sending or receiving messages over WiFi, the problem is usually related to the WiFi network, DNS configuration, app permissions, VPN settings, router restrictions, or a temporary connection issue. This problem can be especially confusing because other apps may continue working normally while WhatsApp appears to be offline. In most cases, however, you can identify and fix the issue without deleting your chats or resetting your entire phone.
WhatsApp app not working on Wi-Fi on phone
The key to troubleshooting this problem is to determine whether the fault comes from WhatsApp itself, your phone, or the particular WiFi network you are using. Start with simple checks such as reconnecting to WiFi and restarting the app, then move to network settings, DNS, VPN, router configuration, and WhatsApp permissions. The following guide covers practical solutions for both Android and iOS, beginning with the steps that are least likely to affect your existing data.
How to fix WhatsApp not working on WiFi on Android
Android phones provide several network and app-level settings that can prevent WhatsApp from communicating correctly over WiFi. Try the following solutions in order and test WhatsApp after each major change.
Restart WiFi and WhatsApp
Begin with the simplest solution because a temporary connection or application error can often cause the problem.
  • Turn WiFi off on your Android phone.
  • Wait approximately 10 seconds and turn WiFi back on.
  • Open WhatsApp and check whether messages can be sent and received.
  • If the problem remains, close WhatsApp completely from the recent-apps screen.
  • Reopen WhatsApp and test the connection again.
Forget and reconnect to the WiFi network
A corrupted or outdated WiFi connection profile can sometimes interfere with specific apps.
  • Open Settings and go to WiFi or Network & Internet.
  • Select the WiFi network that is causing the problem.
  • Choose Forget or Forget network.
  • Turn WiFi off and on again.
  • Select the network and enter its password to reconnect.
  • Open WhatsApp and check whether the connection has been restored.
Disable VPN, Private DNS, or security filtering
VPN applications, custom DNS services, ad blockers, and security tools can sometimes block or incorrectly route WhatsApp traffic.
  • Temporarily disconnect any active VPN.
  • Open Android's network settings and check Private DNS.
  • If a custom DNS provider is configured, temporarily switch to Automatic or the default setting.
  • Temporarily disable network-level ad blockers or firewall applications.
  • Reconnect to WiFi and test WhatsApp.
Clear the WhatsApp cache
Damaged temporary files can occasionally cause unexpected application behavior. Clearing the cache does not normally remove your WhatsApp conversations.
  • Open Settings.
  • Tap Apps or Applications.
  • Select WhatsApp.
  • Tap Storage or Storage & cache.
  • Select Clear cache.
  • Reopen WhatsApp and test the WiFi connection.
Restart the router
If WhatsApp works on another WiFi network but not your home or office WiFi, the router is a strong suspect. Turn the router off, wait briefly, turn it back on, and allow the connection to stabilize. If possible, also test WhatsApp on another WiFi network to confirm whether the issue is specific to your original network.
How to fix WhatsApp not working on WiFi on iOS
iPhone users should approach the issue slightly differently because iOS handles application storage and network permissions differently from Android. These steps can help determine whether the problem is caused by WhatsApp, the iPhone's network configuration, or the WiFi network.
Reconnect your iPhone to WiFi
  • Open Settings and select WiFi.
  • Turn WiFi off and wait a few seconds.
  • Turn WiFi back on and reconnect to your network.
  • Open WhatsApp and send a test message.
Forget and rejoin the network
  • Go to Settings > WiFi.
  • Tap the information icon next to your connected network.
  • Select Forget This Network.
  • Confirm the action.
  • Select the WiFi network again and enter its password.
  • Open WhatsApp and check whether messages now work.
Check WhatsApp network permissions
  • Open Settings on your iPhone.
  • Scroll down and select WhatsApp.
  • Check the available network-related permissions and make sure WhatsApp is not restricted.
  • Also review Settings > Cellular if you need WhatsApp to remain available when switching between WiFi and mobile data.
Disable VPN or network filtering
  • Open your VPN application and temporarily disconnect it.
  • Check whether a security, DNS, or content-filtering application is active.
  • Temporarily disable such services if appropriate.
Reset network settings if necessary
  • Open Settings > General > Transfer or Reset iPhone.
  • Tap Reset.
  • Select Reset Network Settings.
  • Confirm the reset.
  • Reconnect to your WiFi network afterward.
  • Open WhatsApp and test whether it can connect normally.
Remember that resetting network settings removes saved WiFi networks and related network configurations. Make sure you know your WiFi password before performing this step.
Why does WhatsApp work on mobile data but not WiFi?
This pattern is an important diagnostic clue. If WhatsApp immediately works after you turn off WiFi and enable mobile data, the WhatsApp account and application are probably functioning normally. The problem is more likely somewhere between your phone and the WiFi connection. Common causes include DNS problems, router filtering, VPN conflicts, captive portals, firewall restrictions, incorrect network configuration, or temporary ISP issues.
Another useful test is to connect the same phone to a different WiFi network. If WhatsApp works normally elsewhere, your original router or internet connection is likely responsible. If WhatsApp fails on every WiFi network but works on mobile data, investigate the phone's network configuration, VPN, DNS, or application settings.
How to identify whether the router is blocking WhatsApp
Some workplace, school, hotel, public, or managed WiFi networks deliberately restrict certain messaging or communication services. A router can also have parental controls, firewall rules, DNS filtering, or security software that unintentionally interferes with WhatsApp. If other websites load but WhatsApp does not connect, this does not necessarily mean the internet connection is completely healthy for every service.
Try another WiFi network as a comparison. If WhatsApp works there, inspect your router's parental controls, firewall, DNS filtering, and security settings. On managed networks, you may need to contact the network administrator rather than changing settings yourself.
When should you update or reinstall WhatsApp?
If network troubleshooting does not resolve the problem, check whether WhatsApp has an available update through your device's official app store. An outdated application can occasionally contain compatibility problems with newer operating-system or networking components. Restarting the phone after an update can also eliminate temporary system errors.
If reinstalling WhatsApp becomes necessary, back up important chats first and verify that the backup is available before deleting the application. Reinstallation should generally be treated as a later troubleshooting step rather than the first solution, particularly when the problem occurs only on one WiFi network.
What to do if none of these solutions works
If WhatsApp still works on mobile data but fails on every WiFi network, the issue may involve a deeper operating-system configuration or compatibility problem. Check for available Android or iOS updates, restart the device, and test WhatsApp after each update. You can also compare behavior with WhatsApp Web or another device connected to the same WiFi network to determine whether the issue follows the account, phone, or network.
In most cases, WhatsApp working on mobile data but not WiFi points toward a network-specific problem rather than a damaged WhatsApp account. Start by reconnecting to WiFi, forgetting and rejoining the network, and testing another WiFi connection. Android users can additionally clear WhatsApp's cache, while iPhone users can review network settings and, if necessary, reset network settings. VPNs, custom DNS services, firewalls, and router restrictions should also be considered when basic troubleshooting fails.
The safest troubleshooting strategy is to move from simple, reversible changes to more advanced ones. Avoid clearing WhatsApp data or deleting the app until you have confirmed that your chats are backed up. By testing WhatsApp on different networks and following the Android or iOS steps above, you can usually narrow down the source of the problem and restore WhatsApp's WiFi connection without unnecessarily losing personal data.
Prev article: The Audio is not available on Instagram Story? Here's why and how to fix
Next article: How to fix YouTube stopped responding on Android phone/iPhone?
